Unknown 40-180 Switch/Jack
That would make lots of sense, essentially using the radio as an amp.
-Mars
Unknown 40-180 Switch/Jack - by ROXCELLA - 06-02-2011, 09:42 PM
Re: Unknown 40-180 Switch/Jack - by Marsupial - 06-02-2011, 10:41 PM
Re: Unknown 40-180 Switch/Jack - by Chuck Schwark - 06-03-2011, 09:39 AM
Re: Unknown 40-180 Switch/Jack - by Marsupial - 06-03-2011, 10:06 AM
Re: Unknown 40-180 Switch/Jack - by Ron Ramirez - 06-04-2011, 09:14 PM
Re: Unknown 40-180 Switch/Jack - by rocketeer - 06-07-2011, 09:45 PM
Re: Unknown 40-180 Switch/Jack - by codefox1 - 06-08-2011, 12:28 AM
Re: Unknown 40-180 Switch/Jack - by rocketeer - 06-08-2011, 11:09 AM
Re: Unknown 40-180 Switch/Jack - by ROXCELLA - 06-08-2011, 06:22 PM
There are currently 5372 online users. [Complete List]
» 2 Member(s) | 5370 Guest(s)
