smoked resistor
That candohm is a series dropping resistor for the tube heaters, it's a wire wound and is unlikely to be bad since it's a stand alone resistor with no taps. It is possible that it is shorting to that chassis, but a resistance check between the resistor and the chassis would reveal that.
smoked resistor - by gordwa - 01-18-2023, 06:32 PM
RE: smoked resistor - by morzh - 01-18-2023, 08:32 PM
RE: smoked resistor - by Arran - 01-18-2023, 08:58 PM
