IF Transformer open 46-1203
They do however look at the diagram what you will see is the rf filter (the 2 caps and resistor) are mounted in the can most set will have them outside of the IF transformer. You can do likewise.
IF Transformer open 46-1203 - by BUbba - 06-01-2011, 03:09 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-02-2011, 06:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 10:34 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-03-2011, 05:20 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 08:47 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-04-2011, 07:06 PM
Re: IF Transformer open 46-1203 - by Ron Ramirez - 06-04-2011, 09:05 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-07-2011, 12:56 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-07-2011, 07:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:43 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:54 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-23-2011, 06:03 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-23-2011, 11:22 PM
Philco 91 Tuning Condenser
There are currently 10435 online users. [Complete List]
» 2 Member(s) | 10433 Guest(s)
