38-8 shadow meter help
Am feeling a bit dead myself.
For got to mention, some of the SG have a resistor across the coil. Check it to see if it has gone high in value or open.
38-8 shadow meter help - by jstaf40 - 06-02-2011, 07:50 PM
Re: 38-8 shadow meter help - by 7estatdef - 06-02-2011, 09:21 PM
Re: 38-8 shadow meter help - by jstaf40 - 06-03-2011, 12:51 PM
Re: 38-8 shadow meter help - by 7estatdef - 06-03-2011, 05:24 PM
Re: 38-8 shadow meter help - by Chuck Schwark - 06-04-2011, 09:41 AM
The speaker table error?
Philco 70 antenna lead
