116B dial drive disassembly surprise
Hi mbhdesign, about 2 years ago I came across a 16B, the predecessor of your 116 at a local auction house. I knew it was one of Philco’s best at the time and ran over to it. Once I got to looking at it my enthusiasm waned. In addition to the cabinet falling apart, the stench emanating from it and the obvious rodent damage was a killer. I walked away! It was the only time I ever remember seeing one in the raw.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
462ron - by 462ron - 01-21-2023, 11:23 AM
Philco 91 Tuning Condenser
There are currently 8109 online users. [Complete List]
» 2 Member(s) | 8107 Guest(s)
