40-145 Loop Antenna Help
Rob,
Just watched Jim's videos about this particular antenna. I'm a fan of Jim's channel, but hadn't realized he had just uploaded a video on this antenna. Would have been nice to have found that a few weeks ago, but still, the challenge of figuring something out is part of the fun. I noticed the format of his antenna is rather unique even though it follows the same general principle as outlined in the schematic. Unlike Jim, I noticed a considerable difference when attaching this antenna instead of using a length of wire attached to the back. Almost all of the distortion of the signal this set was experiencing (like being underwater) was eliminated.
Again, thanks.
Jim
40-145 Loop Antenna Help - by percyjd - 01-08-2023, 08:59 PM
RE: 40-145 Loop Antenna Help - by GarySP - 01-08-2023, 09:40 PM
RE: 40-145 Loop Antenna Help - by percyjd - 01-21-2023, 09:31 AM
RE: 40-145 Loop Antenna Help - by David - 01-21-2023, 10:59 AM
RE: 40-145 Loop Antenna Help - by Radioroslyn - 01-21-2023, 07:47 PM
RE: 40-145 Loop Antenna Help - by radiorich - 01-22-2023, 02:59 AM
RE: 40-145 Loop Antenna Help - by RodB - 01-22-2023, 10:33 AM
RE: 40-145 Loop Antenna Help - by radiorich - 01-22-2023, 12:05 PM
RE: 40-145 Loop Antenna Help - by percyjd - 01-22-2023, 01:19 PM
RE: 40-145 Loop Antenna Help - by klemer - 07-01-2023, 08:50 PM
RE: 40-145 Loop Antenna Help - by percyjd - 07-02-2023, 09:22 AM
There are currently 9425 online users. [Complete List]
» 1 Member(s) | 9424 Guest(s)
