41-280 Howard’s restorer color
I've used Howard restoring to touch up the finish on veneer and it works fine. I use it mostly to do the area around volume control and tuning knobs. I use go-jo to clean the the dirt and finger stains then light buffing with 0000 steel wool then blend the area with Howard, usually walnut. Try testing a small area out of site to make sure it works. It comes off fairly easy with a cloth and the steel wool if you want to test a different stain.
41-280 Howard’s restorer color - by Jeff - 01-22-2023, 11:53 AM
RE: 41-280 Howard’s restorer color - by RodB - 01-22-2023, 09:07 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8715 online users. [Complete List]
» 1 Member(s) | 8714 Guest(s)
