IF Transformer open 46-1203
Cool thanx so If I understand this correctly I can get mostly any IF transformer with primary and 2ndary and for the 5th wire just put the 2 Cap and 47K resistor network either inside or outside the can myself.
As long as it is rated for 455KHZ..
IF Transformer open 46-1203 - by BUbba - 06-01-2011, 03:09 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-02-2011, 06:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 10:34 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-03-2011, 05:20 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 08:47 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-04-2011, 07:06 PM
Re: IF Transformer open 46-1203 - by Ron Ramirez - 06-04-2011, 09:05 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-07-2011, 12:56 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-07-2011, 07:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:43 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:54 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-23-2011, 06:03 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-23-2011, 11:22 PM
Philco 91 Tuning Condenser
There are currently 10303 online users. [Complete List]
» 2 Member(s) | 10301 Guest(s)
