38.7 Console Model Radio
Hi and welcome,
You inherited one of the 1938 conecentric Philcos. Only a few models used that tuning system and it was a '38 only thing. Here's the service info for your chassis https://philcoradio.com/library/download...l.%202.pdf  For starters you'll need to replace #3 .05 mf 630v,#11 10mf 450v X2,#14 .1 mf 630v,#24 .01 mf 630v,#28, .015mf 630v #30, .1mf 630v #34, .015mf  630v #37, .033 630v #38, .006 630v #40, .008mf 630v #45 22mf 450v, and #47 and dual .015 mf @ 600v safety caps.
#11,11A and 45 are electrolytic capacitors, the others are mylar or film capacitors. Some of the values I tweak a little as they are not common any more.The issue w/these parts is that they degrade over the years and can internally short. This is bad. It can damage other parts in the set or worst case could cause a fire [Image: https://philcoradio.com/phorum/images/sm...n_evil.gif] Most of the time they are electrically leaky. Which means that they cause excessive current flow which taxes parts in the power supply circuit. Here's a link to where a lot of us get are caps. http://www.tuberadios.com/capacitors/
GL w/your new project.
ps Saw John's post and you miss the rubber wire by a year. That's a '39-42 thing.
38.7 Console Model Radio - by Atlas161 - 01-28-2023, 10:08 PM
RE: 38.7 Console Model Radio - by MrFixr55 - 01-29-2023, 01:30 AM
RE: 38-7 Console Model Radio - by Radioroslyn - 01-29-2023, 02:39 AM
RE: 38.7 Console Model Radio - by radiorich - 01-29-2023, 03:06 AM
RE: 38.7 Console Model Radio - by Radioroslyn - 01-29-2023, 09:21 AM
RE: 38.7 Console Model Radio - by GarySP - 01-29-2023, 01:37 PM
RE: 38.7 Console Model Radio - by klondike98 - 01-29-2023, 08:13 PM
RE: 38.7 Console Model Radio - by poulsbobill - 01-30-2023, 12:09 PM
RE: 38.7 Console Model Radio - by Atlas161 - 01-30-2023, 03:03 PM
RE: 38.7 Console Model Radio - by MrFixr55 - 01-30-2023, 07:12 PM
RE: 38.7 Console Model Radio - by poulsbobill - 01-31-2023, 12:00 PM
RE: 38.7 Console Model Radio - by Simon Wa3uay - 02-10-2023, 08:01 PM
RE: 38.7 Console Model Radio - by MrFixr55 - 02-11-2023, 10:18 PM
RE: 38.7 Console Model Radio - by GarySP - 02-12-2023, 08:49 AM
RE: 38.7 Console Model Radio - by Radioroslyn - 02-12-2023, 11:19 AM
RE: 38.7 Console Model Radio - by John Bartley - 02-12-2023, 12:16 PM
RE: 38.7 Console Model Radio - by Chas - 02-12-2023, 06:53 PM
RE: 38.7 Console Model Radio - by radiorich - 02-12-2023, 11:42 PM
RE: 38.7 Console Model Radio - by radiorich - 02-12-2023, 11:48 PM
RE: 38.7 Console Model Radio - by MrFixr55 - 02-13-2023, 08:36 PM
There are currently 10582 online users. [Complete List]
» 2 Member(s) | 10580 Guest(s)
