General Television - unknown model
Try JB Weld, applying enough to fill the stripped threads but not fully pack the screw cavity. A toothpick works well for this. After it hardens you can re-tap without having to drill out the excess first. Take care and BE HEALTHY! Gary
RE: General Television - unknown model - by David - 01-29-2023, 08:51 PM
RE: General Television - unknown model - by GarySP - 01-29-2023, 09:36 PM
