Model 16 high frequency hum.
Fixed it. I started grounding the grids of the 42 output tubes, no change. Then the 42 second audio, no change. Then the grid cap of the 77 first audio no tone noise. I replaced the 77 first audio, problem fixed. No noise, radio plays and sounds great. Thanks to all that looked at this thread. Mike
Model 16 high frequency hum. - by Mikeym53 - 01-31-2023, 11:48 PM
RE: Model 16 high frequency hum. - by Mikeym53 - 02-01-2023, 02:16 AM
RE: Model 16 high frequency hum. - by morzh - 02-01-2023, 08:05 PM
There are currently 9236 online users. [Complete List]
» 2 Member(s) | 9234 Guest(s)
