model 15
Thanks Brad.  I'm going to use those two values which I also think is correct from what little I have been able to find.  Kind of strange that the pt.# can't be found anywhere.  I thought this chassis had been untouched but it has a mershon electrolytic can and a Philco aluminum electrolytic can.  The aluminum can has a sticker on it with the pt.# 7556.  So I checked the Phorum parts lists and found that can was used in 1936.  So I think that can was changed on this radio at some early time in it's life.  Thanks again
Dick
model 15 - by madsowry - 01-28-2023, 03:48 PM
RE: model 15 - by Brad Winder - 01-28-2023, 05:27 PM
RE: model 15 - by madsowry - 01-28-2023, 09:13 PM
RE: model 15 - by Brad Winder - 01-29-2023, 01:17 PM
RE: model 15 - by madsowry - 01-29-2023, 07:29 PM
RE: model 15 - by madsowry - 01-30-2023, 04:11 PM
RE: model 15 - by David - 01-30-2023, 08:16 PM
RE: model 15 - by madsowry - 01-30-2023, 08:47 PM
RE: model 15 - by David - 01-30-2023, 08:59 PM
RE: model 15 - by Brad Winder - 01-30-2023, 11:16 PM
RE: model 15 - by madsowry - 01-30-2023, 11:33 PM
RE: model 15 - by Brad Winder - 01-31-2023, 12:02 PM
RE: model 15 - by madsowry - 01-31-2023, 06:55 PM
RE: model 15 - by admin - 01-31-2023, 07:49 PM
RE: model 15 - by madsowry - 01-31-2023, 09:15 PM
RE: model 15 - by admin - 02-01-2023, 10:22 AM
RE: model 15 - by Brad Winder - 02-01-2023, 11:45 AM
RE: model 15 - by madsowry - 02-01-2023, 12:42 PM
RE: model 15 - by Brad Winder - 02-01-2023, 09:32 PM
RE: model 15 - by madsowry - 02-02-2023, 12:20 AM
RE: model 15 - by Brad Winder - 02-03-2023, 11:03 AM
RE: model 15 - by madsowry - 02-03-2023, 07:50 PM
RE: model 15 - by madsowry - 02-19-2023, 02:34 PM
Philco 91 Tuning Condenser
There are currently 8687 online users. [Complete List]
» 3 Member(s) | 8684 Guest(s)
