47-1230 replacement phono cartridge
This the cartridge from VOM
P51-3 Ceramic mono cartridge with 3 mil sapphire needle for 78 rpm records Astatic 5
RE: 47-1230 replacement phono cartridge - by rstokes58 - 02-04-2023, 05:53 PM
Philco 91 Tuning Condenser
There are currently 8834 online users. [Complete List]
» 2 Member(s) | 8832 Guest(s)
