Philco Special Services radio
I am new and I found an old philco special services radio I think that is what it has on the dial and it still works kind of all I can get is static but I see the tubes lighting up in the back. can you help me as the site does not talk about the radios from 43-45. I can find nothing anywhere about them. thank you for your help, Rosalie Searfoss
Philco Special Services radio - by rsearfoss - 02-07-2023, 01:43 PM
RE: Philco Special Services radio - by klondike98 - 02-07-2023, 02:10 PM
RE: Philco Special Services radio - by rsearfoss - 02-07-2023, 03:34 PM
RE: Philco Special Services radio - by rsearfoss - 02-07-2023, 03:37 PM
RE: Philco Special Services radio - by rsearfoss - 02-07-2023, 08:07 PM
RE: Philco Special Services radio - by klondike98 - 02-08-2023, 12:35 AM
