Philco 86 Voltages
All capacitors I have replaced have been with the same capacitances.
So while I’m waiting for more parts, decided to document the existing voltages…
All of my AC voltages (A, B & C) off the power transformer are spot on….. My DC voltages are a whole different story…..
D & G = 112
E = 48
F = 244
Plate voltage on both 71a tubes = 240
Plate voltage on all 3 A.F. 26 tubes = 110
All the tubes light up and I can faintly tune a local station….
Philco 86 Voltages - by Tiddat33 - 02-06-2023, 12:13 AM
RE: Philco 86 Voltages - by MrFixr55 - 02-06-2023, 08:52 AM
RE: Philco 86 Voltages - by Tiddat33 - 02-06-2023, 10:44 PM
RE: Philco 86 Voltages - by MrFixr55 - 02-06-2023, 10:58 PM
RE: Philco 86 Voltages - by RodB - 02-07-2023, 10:32 AM
RE: Philco 86 Voltages - by Ron Ramirez - 02-07-2023, 01:53 PM
RE: Philco 86 Voltages - by RodB - 02-07-2023, 02:46 PM
RE: Philco 86 Voltages - by Tiddat33 - 02-07-2023, 09:07 PM
RE: Philco 86 Voltages - by Radioroslyn - 02-08-2023, 01:15 PM
RE: Philco 86 Voltages - by MrFixr55 - 02-08-2023, 03:51 PM
RE: Philco 86 Voltages - by Ron Ramirez - 02-08-2023, 03:56 PM
RE: Philco 86 Voltages - by RodB - 02-08-2023, 04:06 PM
RE: Philco 86 Voltages - by Arran - 02-08-2023, 04:08 PM
RE: Philco 86 Voltages - by Tiddat33 - 02-08-2023, 09:58 PM
RE: Philco 86 Voltages - by Radioroslyn - 02-08-2023, 10:52 PM
RE: Philco 86 Voltages - by radiorich - 02-09-2023, 09:31 AM
RE: Philco 86 Voltages - by Tiddat33 - 02-12-2023, 06:50 PM
RE: Philco 86 Voltages - by RodB - 02-13-2023, 10:37 AM
RE: Philco 86 Voltages - by Tiddat33 - 02-13-2023, 05:10 PM
RE: Philco 86 Voltages - by Ron Ramirez - 02-13-2023, 08:42 PM
RE: Philco 86 Voltages - by RodB - 02-13-2023, 09:03 PM
RE: Philco 86 Voltages - by Ron Ramirez - 02-14-2023, 09:19 AM
RE: Philco 86 Voltages - by Arran - 02-14-2023, 02:20 PM
RE: Philco 86 Voltages - by Ron Ramirez - 02-14-2023, 02:29 PM
RE: Philco 86 Voltages - by RodB - 02-14-2023, 02:29 PM
Philco 91 Tuning Condenser
There are currently 8738 online users. [Complete List]
» 3 Member(s) | 8735 Guest(s)
