Model 80 veneer
I am trying to restore this model 80 and have removed the veneer on the dome part due to many broken and missing sections.
Now the question I have what is the best way to get the bend in the veneer to glue it to the basic structure. I was thinking of soaking it in water then clamping it until it dries.
I would appreciate some advice on this.
George
Model 80 veneer - by texan george - 02-08-2023, 04:32 PM
RE: Model 80 veneer - by Radioroslyn - 02-08-2023, 05:00 PM
RE: Model 80 veneer - by texan george - 02-09-2023, 08:15 AM
RE: Model 80 veneer - by John Bartley - 02-09-2023, 05:18 PM
RE: Model 80 veneer - by texan george - 02-10-2023, 07:22 AM
RE: Model 80 veneer - by Arran - 02-14-2023, 02:16 PM
RE: Model 80 veneer - by texan george - 02-14-2023, 03:15 PM
RE: Model 80 veneer - by texan george - 02-26-2023, 03:57 PM
RE: Model 80 veneer - by MrFixr55 - 02-27-2023, 12:35 AM
RE: Model 80 veneer - by texan george - 02-27-2023, 09:33 AM
RE: Model 80 veneer - by David - 02-27-2023, 08:43 PM
RE: Model 80 veneer - by radiorich - 02-27-2023, 09:17 PM
RE: Model 80 veneer - by texan george - 02-28-2023, 08:19 AM
RE: Model 80 veneer - by radiorich - 02-28-2023, 09:17 AM
RE: Model 80 veneer - by John Bartley - 02-28-2023, 10:13 AM
