Philco 90 pp 47 Restoration Questions
According to the Bintliff bakelite block book, the 6287-B block should have 1 .15 capacitor in there. I think i found my mistake, I put 2 .1s in it and should only have put 1.
RE: Philco 90 pp 47 - by Radioroslyn - 12-04-2022, 03:31 PM
RE: Philco 90 pp 47 - by buster757 - 12-04-2022, 04:19 PM
RE: Philco 90 pp 47 - by buster757 - 12-04-2022, 04:22 PM
RE: Philco 90 pp 47 - by buster757 - 12-04-2022, 04:36 PM
RE: Philco 90 pp 47 - by morzh - 12-04-2022, 10:04 PM
RE: Philco 90 pp 47 - by radiorich - 12-05-2022, 02:03 AM
RE: Philco 90 pp 47 - by Radioroslyn - 12-05-2022, 01:26 PM
RE: Philco 90 pp 47 - by morzh - 12-05-2022, 11:19 PM
RE: Philco 90 pp 47 - by MrFixr55 - 12-06-2022, 09:24 AM
RE: Philco 90 pp 47 Restoration Questions - by buster757 - 02-09-2023, 12:28 PM
Philco 90 pp 47 - by buster757 - 02-08-2023, 04:23 PM
There are currently 8557 online users. [Complete List]
» 1 Member(s) | 8556 Guest(s)
