89B, v3 almost there!
Keep up the good work, Steve. Icon_thumbup
89B, v3 almost there! - by tubenutt - 06-05-2011, 02:46 PM
Re: 89B, v3 almost there! - by 7estatdef - 06-05-2011, 04:26 PM
Re: 89B, v3 almost there! - by Ron Ramirez - 06-05-2011, 05:19 PM
Re: 89B, v3 almost there! - by tubenutt - 06-05-2011, 06:11 PM
The speaker table error?
Philco 70 antenna lead
