FM alignment on 51-1734
I will be doing a FM alignment on a 9.1mhz IF frequency 51-1734 radio and would like to know if I can do it using an oscilloscope such as a Tektronix 2236 and a BK 4040 sweep generator with a Heathkit SG8 or do I need other test equipment?
FM alignment on 51-1734 - by Wilryn - 02-22-2023, 11:35 AM
RE: FM alignment on 51-1734 - by Wilryn - 02-22-2023, 11:58 AM
RE: FM alignment on 51-1734 - by klondike98 - 02-22-2023, 01:30 PM
RE: FM alignment on 51-1734 - by Wilryn - 02-24-2023, 01:18 PM
RE: FM alignment on 51-1734 - by RodB - 02-24-2023, 11:19 PM
Eico 232 VTVM Schematic
