Philco 38-690 restoration completed
After more than a year - it is finished now.
Grill cloth is somewhat loose - I'll change that in the future.
It was:
[attachment=2]
[attachment=1]
It is now:
[attachment=0]
More pictures will follow.
I tried to keep it as authentic, as possible, so kept part of the original finish and grill cloth.
It was also electronically restored.
Works perfectly. "Magnetic tuning" is fantastic. A lot of stations, big sound.
Philco 38-690 restoration completed - by Ragazzo - 06-07-2011, 05:09 PM
Re: Philco 38-690 restoration completed - by radoez - 06-10-2011, 08:13 PM
There are currently 9898 online users. [Complete List]
» 1 Member(s) | 9897 Guest(s)
