42-1003 -need advice
If the candohm is measuring OK I leave them alone as I would with the 15 ohm resistor. The rubber coated wires will likely crumble as you work to replace the paper capacitors. Some colors are less brittle than others but I find I'm often replacing or covering most of them. If I haven't disturbed a wire and it looks intact and it still has some pliability in the rubber I may leave it alone. Other folks may have other opinions I'm sure...
42-1003 -need advice - by streetmechanic - 02-22-2023, 09:54 PM
RE: 42-1003 -need advice - by klondike98 - 02-23-2023, 02:09 PM
RE: 42-1003 -need advice - by Radioroslyn - 02-23-2023, 08:06 PM
RE: 42-1003 -need advice - by MrFixr55 - 02-24-2023, 01:23 AM
RE: 42-1003 -need advice - by Ron Ramirez - 02-24-2023, 11:56 AM
RE: 42-1003 -need advice - by streetmechanic - 02-24-2023, 12:26 PM
RE: 42-1003 -need advice - by Chas - 02-24-2023, 01:03 PM
There are currently 8871 online users. [Complete List]
» 1 Member(s) | 8870 Guest(s)
