Philco 38-690 restoration completed
Mighty fine piece of work there. Inspiring the rest of us.
Philco 38-690 restoration completed - by Ragazzo - 06-07-2011, 05:09 PM
Re: Philco 38-690 restoration completed - by Uffda - 06-07-2011, 05:38 PM
Re: Philco 38-690 restoration completed - by radoez - 06-10-2011, 08:13 PM
There are currently 10218 online users. [Complete List]
» 1 Member(s) | 10217 Guest(s)
