Another Update on model 87 restoration
wendell Wrote:The hum is more like a buzz I guess.
Wendell, my first restoration was a TRF, and it had a buzz too.
Add a line filter cap and see if it helps. If you don't have a "safety cap" handy now, just use a 630 V/.022 uF poly cap. You could also use a .01, .047...or whatever for now.
If you're not familiar with safety caps, look here:
http://www.justradios.com/safetytips.html
-Greg
Re: Another Update on model 87 restoration - by gvel - 08-01-2011, 07:34 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6309 online users. [Complete List]
» 2 Member(s) | 6307 Guest(s)
