box style shadow meter and magnetism woes
Chuck Schwark has a good article on shadow meters on his Philco Repair Bench site in case you have not seen it:
https://www.philcorepairbench.com/shadow...justments/
RE: box style shadow meter and magnetism woes - by klondike98 - 03-05-2023, 05:22 PM
Philco 91 Tuning Condenser
There are currently 8739 online users. [Complete List]
» 2 Member(s) | 8737 Guest(s)
