Numbers inside of Rosette knobs
Oh great...more "numbers matching" LOL!
I think they are probably mold or casting numbers. Or possible it's the number of the machine used to make the casting. Manufacturers usually keep track of details like that, so they are able to track down causes of defects for quality control.
Numbers inside of Rosette knobs - by Jhunt - 03-06-2023, 07:32 AM
RE: Numbers inside of Rosette knobs - by RodB - 03-06-2023, 09:05 AM
RE: Numbers inside of Rosette knobs - by Jhunt - 03-06-2023, 10:09 AM
RE: Numbers inside of Rosette knobs - by Brad Winder - 03-06-2023, 10:11 AM
RE: Numbers inside of Rosette knobs - by Arran - 03-13-2023, 02:50 AM
