Philco 38-690 restoration completed
Ed, nothing has left. I re-stuffed all paper caps in power supply chassis, even if part of them were good. As a matter of fact I saw a bunch of paper caps being sold on e-bay now. OK, it is German E-bay: http://cgi.ebay.de/320663200718
Philco 38-690 restoration completed - by Ragazzo - 06-07-2011, 05:09 PM
Re: Philco 38-690 restoration completed - by Ragazzo - 06-09-2011, 10:06 AM
Re: Philco 38-690 restoration completed - by radoez - 06-10-2011, 08:13 PM
There are currently 10002 online users. [Complete List]
» 1 Member(s) | 10001 Guest(s)
