Philco 118 Chassis Restoration
Well, it could be an advebture. But the clamsheel cabinet is complex, will likely require tools made specifically for it (which is what Steve did for Philco 20) and could be a long multy-hour project. Restoring one probably is simpler.
Philco 118 Chassis Restoration - by Steve Davis - 03-13-2023, 03:31 PM
RE: Philco 118 Chassis Restoration - by morzh - 03-13-2023, 04:51 PM
RE: Philco 118 Chassis Restoration - by GarySP - 03-13-2023, 06:10 PM
RE: Philco 118 Chassis Restoration - by morzh - 03-13-2023, 07:14 PM
RE: Philco 118 Chassis Restoration - by radiorich - 03-13-2023, 07:35 PM
RE: Philco 118 Chassis Restoration - by morzh - 03-13-2023, 08:14 PM
RE: Philco 118 Chassis Restoration - by RodB - 03-13-2023, 08:47 PM
RE: Philco 118 Chassis Restoration - by Arran - 03-13-2023, 09:38 PM
RE: Philco 118 Chassis Restoration - by morzh - 03-13-2023, 11:23 PM
RE: Philco 118 Chassis Restoration - by RadioSvit - 03-14-2023, 06:48 AM
RE: Philco 118 Chassis Restoration - by GarySP - 03-14-2023, 08:48 AM
RE: Philco 118 Chassis Restoration - by radiorich - 03-14-2023, 09:07 AM
RE: Philco 118 Chassis Restoration - by morzh - 03-15-2023, 08:53 AM
RE: Philco 118 Chassis Restoration - by GarySP - 03-15-2023, 08:59 AM
RE: Philco 118 Chassis Restoration - by RodB - 03-15-2023, 10:25 AM
RE: Philco 118 Chassis Restoration - by Chas - 03-15-2023, 11:47 AM
RE: Philco 118 Chassis Restoration - by morzh - 03-16-2023, 02:39 PM
RE: Philco 118 Chassis Restoration - by radiorich - 03-17-2023, 09:42 AM
RE: Philco 118 Chassis Restoration - by morzh - 03-18-2023, 02:27 PM
RE: Philco 118 Chassis Restoration - by MrFixr55 - 03-18-2023, 07:27 PM
RE: Philco 118 Chassis Restoration - by GarySP - 03-30-2023, 06:39 PM
RE: Philco 118 Chassis Restoration - by MrFixr55 - 03-31-2023, 11:38 PM
RE: Philco 118 Chassis Restoration - by MrFixr55 - 04-18-2023, 12:43 AM
RE: Philco 118 Chassis Restoration - by radiorich - 04-19-2023, 07:24 PM
RE: Philco 118 Chassis Restoration - by radiorich - 04-21-2023, 08:01 AM
Eico 232 VTVM Schematic
There are currently 9368 online users. [Complete List]
» 2 Member(s) | 9366 Guest(s)
