Magnavox cr192
Phorum member Mikhail7 might be interested in your CR-192, "flattopcomb." You might send him a PM.
Another Phorum member, w4rtc (Joe), has a Magnavox, but I think he already has an FM tuner for his set? Bill Cahill is another member with a Maggie...and Doug Houston has several Maggie sets, I think.
Magnavox cr192 - by flattopcomb - 06-07-2011, 02:05 PM
Re: Magnavox cr192 - by 7estatdef - 06-07-2011, 03:35 PM
Re: Magnavox cr192 - by Ron Ramirez - 06-07-2011, 09:07 PM
Re: Magnavox cr192 - by flattopcomb - 06-09-2011, 12:49 PM
Re: Magnavox cr192 - by Ron Ramirez - 06-09-2011, 01:10 PM
Re: Magnavox cr192 - by Ron Ramirez - 06-09-2011, 01:46 PM
