info for aligning philco recivers
Benny I found this in the Philco Library under Shop Talk model notes …
https://philcoradio.com/library/index.ph...-model-90/
https://philcoradio.com/library/wp-conte...Vol.-1.pdf
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
info for aligning philco recivers - by mg34.42 - 03-14-2023, 11:37 PM
462ron - by 462ron - 03-15-2023, 08:29 AM
