42-1003 -need advice
I'm not sure where this fits in the Phorum- it's sort of a "restoration philosophy" question. The 42-1003 is a simple series-string radio with the addition of a Beam-Of Light record player, an addition that's a little weird by modern standards, but in a fun way. Here's the question: the under-chassis wiring job (untouched since 1942) is surprisingly poor. Sloppy solder joints and rubber-covered wire snugged tight against terminals it should be insulated from (meaning only the tiniest fraction-of-an-inch of crumbly rubber now separates B+ from where it shouldn't be).  Wires to tube socket terminals are securely (and I mean SECURELY) threaded through and wound around- apparently nobody was supposed to replace any parts- ever.  So... do I  do a hogged-up repair job (for example tacking new parts to stubs of existing wires) and put up with my own poor workmanship OR do I (for example) drill out rivets, throw away the original tube sockets, and "do it right"?
  With a little perspective I see this is an interesting insight into what was probably a stressful time at Tioga and C Streets as we were sliding into WWII and experienced help was getting scarce, but I also want this set to end up as something to be proud of, or at least content with. What do you guys do?
-Dave
42-1003 -need advice - by streetmechanic - 03-23-2023, 02:42 AM
RE: 42-1003 -need advice - by morzh - 03-23-2023, 08:27 AM
RE: 42-1003 -need advice - by Chas - 03-23-2023, 08:50 AM
RE: 42-1003 -need advice - by Arran - 03-23-2023, 01:00 PM
RE: 42-1003 -need advice - by MrFixr55 - 03-23-2023, 05:24 PM
RE: 42-1003 -need advice - by morzh - 03-23-2023, 07:12 PM
RE: 42-1003 -need advice - by jtiner - 03-29-2023, 10:37 AM
RE: 42-1003 -need advice - by Ron Ramirez - 03-29-2023, 10:44 AM
RE: 42-1003 -need advice - by jtiner - 03-29-2023, 10:58 AM
RE: 42-1003 -need advice - by Ron Ramirez - 03-30-2023, 07:14 AM
RE: 42-1003 -need advice - by streetmechanic - 04-08-2023, 09:34 AM
RE: 42-1003 -need advice - by radiorich - 04-08-2023, 12:20 PM
