51-530 popping noise
I'll try the radio in a different location to see if interference is a factor. I did replace all capacitors, but I'll check the across the line cap to make sure it's not open. I'm not eager to open the IF cans! Thanks.
51-530 popping noise - by mancave - 03-21-2023, 06:51 AM
RE: 51-530 popping noise - by radiorich - 03-21-2023, 08:04 AM
RE: 51-530 popping noise - by RodB - 03-21-2023, 10:15 AM
RE: 51-530 popping noise - by Arran - 03-23-2023, 01:16 PM
RE: 51-530 popping noise - by mancave - 03-23-2023, 03:05 PM
RE: 51-530 popping noise - by morzh - 03-23-2023, 04:18 PM
RE: 51-530 popping noise - by MrFixr55 - 03-24-2023, 09:03 AM
RE: 51-530 popping noise - by Ron Ramirez - 03-24-2023, 09:14 AM
RE: 51-530 popping noise - by Chas - 03-24-2023, 10:06 AM
Philco 91 Tuning Condenser
There are currently 10370 online users. [Complete List]
» 2 Member(s) | 10368 Guest(s)
