Philco 84 transformer
I am in need of some help.
I have a Philco Model 84 (I think model b) that I have decided to restore.   All of the leads attached to the power transformer are crusty and the shielding is breaking.  I removed the transformer and plan to re-sleeve them.  I gathered up some test equipment, isolation transformer, variac, and I built a dim bulb tester.
Now the problem.  This transformer has 9 leads. The schematic I have for the radio shows the transformer should have 10 leads, two secondaries with a center tap on each and the third without. I found another schematic for a 37-84 it shows only 9 leads but with different tubes.  I found on ebay someone selling a transformer with the same model number (different year) but it has 3 leads for the primary where I only have two.
All leads on mine ohm out so no shorts.  I found the center tap for one of the secondary windings.  I tested up to 115 volts and I see 5v on one winding, 270v on another and 3 on another.
Does anyone have any data (expected voltage, ohms etc) for a 32-7180N transformer.  My date code is 6-35
Thanks
(fyi I am new to this)
Philco 84 transformer - by SanDegan - 03-24-2023, 11:02 AM
RE: Philco 84 transformer - by Radioroslyn - 03-24-2023, 04:11 PM
RE: Philco 84 transformer - by SanDegan - 03-26-2023, 03:39 PM
RE: Philco 84 transformer - by Radioroslyn - 03-26-2023, 06:46 PM
RE: Philco 84 transformer - by MrFixr55 - 03-26-2023, 09:11 PM
RE: Philco 84 transformer - by SanDegan - 04-16-2023, 04:59 PM
RE: Philco 84 transformer - by SanDegan - 04-16-2023, 08:59 PM
RE: Philco 84 transformer - by MrFixr55 - 04-17-2023, 07:47 AM
RE: Philco 84 transformer - by radiorich - 04-17-2023, 08:12 AM
RE: Philco 84 transformer - by Radioroslyn - 04-17-2023, 12:03 PM
