New Guy with a 48-1276
Hello,
That is a great looking console that you have there!
My 39-116 used motorized volume control because the remote control operated the volume. I just used a 33mfd, 100-volt non-polarized electrolytic cap for this application. seems to operate just fine.
Good luck
New Guy with a 48-1276 - by BHorn - 03-24-2023, 08:18 PM
RE: New Guy with a 48-1276 - by patrician56 - 03-25-2023, 10:04 AM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 12:24 PM
RE: New Guy with a 48-1276 - by BHorn - 03-25-2023, 01:11 PM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 08:14 PM
RE: New Guy with a 48-1276 - by MrFixr55 - 03-25-2023, 08:32 PM
RE: New Guy with a 48-1276 - by BHorn - 03-25-2023, 09:04 PM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 11:37 PM
RE: New Guy with a 48-1276 - by MrFixr55 - 03-25-2023, 11:42 PM
RE: New Guy with a 48-1276 - by BHorn - 03-29-2023, 01:02 AM
RE: New Guy with a 48-1276 - by BHorn - 04-04-2023, 08:24 PM
RE: New Guy with a 48-1276 - by morzh - 04-04-2023, 08:50 PM
RE: New Guy with a 48-1276 - by BHorn - 04-04-2023, 08:59 PM
RE: New Guy with a 48-1276 - by radiorich - 04-05-2023, 12:52 AM
There are currently 3934 online users. [Complete List]
» 1 Member(s) | 3933 Guest(s)
