New Guy with a 48-1276
Thanks for the replies. I mis spoke when I said it was a run cap, it’s actually listed as a start cap in the service manual, with a later service addendum to add a second 30mfd cap in parallel. I have a couple of 33mfd 100v electrolytic audio crossover listed caps on the way.
Thanks for the compliments, it really is beautiful in person. Once the electrical service is done, I can’t wait to give the cabinet a good cleaning, and waxing to see it at its best. I plan to add a Bluetooth module, and gift it to a dear Friend that has a love for music, as well as appreciates things with history. I bought it from the family that bought it new, and heard all the memories associated with it. I’m sure my Friend will make even more memories with it with her children.
New Guy with a 48-1276 - by BHorn - 03-24-2023, 08:18 PM
RE: New Guy with a 48-1276 - by patrician56 - 03-25-2023, 10:04 AM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 12:24 PM
RE: New Guy with a 48-1276 - by BHorn - 03-25-2023, 01:11 PM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 08:14 PM
RE: New Guy with a 48-1276 - by MrFixr55 - 03-25-2023, 08:32 PM
RE: New Guy with a 48-1276 - by BHorn - 03-25-2023, 09:04 PM
RE: New Guy with a 48-1276 - by morzh - 03-25-2023, 11:37 PM
RE: New Guy with a 48-1276 - by MrFixr55 - 03-25-2023, 11:42 PM
RE: New Guy with a 48-1276 - by BHorn - 03-29-2023, 01:02 AM
RE: New Guy with a 48-1276 - by BHorn - 04-04-2023, 08:24 PM
RE: New Guy with a 48-1276 - by morzh - 04-04-2023, 08:50 PM
RE: New Guy with a 48-1276 - by BHorn - 04-04-2023, 08:59 PM
RE: New Guy with a 48-1276 - by radiorich - 04-05-2023, 12:52 AM
There are currently 5332 online users. [Complete List]
» 2 Member(s) | 5330 Guest(s)
