Philco model 42-380 lost cap connection
Plate to plate capacitor make it a 1000 vdc (or more) type. Someone probably clipped it out when it shorted. It's there to tame oscillations and cancel harmonics above the audible range. A 1 KV ceramic is OK and keep the lead dress as tight as possible.
Re: Philco model 42-380 lost cap connection - by codefox1 - 06-10-2011, 10:58 AM
The speaker table error?
Philco 70 antenna lead
