HELP WITH A PHILCO 91 OSCILLATOR COIL PLEASE
For the folks following at home: https://philcoradio.com/library/download...%20129.pdf
I doubt you would be able to get an osc coil design for a 455kc IF to tune down low enough to use it at 260kc. That's just shy of 200kc. It's got a slug but maybe it will adjust 20kc not 10x that. Adding more capacitance across the two tuned circuits may work. But at some point the C overcomes the L and it doesn't work. At 200kc I thinking your past that point.
Philco didn't use the 260kc IF in very many of there sets. Most are right around the same time frame as the 91. Like one version of the model 90 did and I think the 200X may have. You can go there the alignment data and look for the 260kc IF.
Wouldn't think about changing the osc and IF to 455kc because then you will have tracking issues.
It's a bit of a pickle
RE: HELP WITH A PHILCO 91 OSCILLATOR COIL PLEASE - by Radioroslyn - 03-31-2023, 09:53 AM
Eico 232 VTVM Schematic
There are currently 9020 online users. [Complete List]
» 1 Member(s) | 9019 Guest(s)
