Crosley Trirdyn 1121
Thanks Chas, the audio coils all ohmed out OK. The capacitors were "open" when checking with an ohm meter, but I don't have a capcitor tester that measures for leakage at higher voltages. The multimeter capacitance measurement was nominally OK although they are at the low end for measurement on that meter. The thermoforming MUD parts are already pretty dull, some from dirt and probably from cleaning. I'll see what I can do to improve its look. I'll also try to add some white paint in the lettering in some places as they are a bit off.
Thanks Terry, I should have known that you would have seen one of these in the past!!
Crosley Trirdyn 1121 - by klondike98 - 04-08-2023, 09:29 PM
RE: Crosley Trirdyn 1121 - by Ron Ramirez - 04-09-2023, 08:12 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 08:50 AM
RE: Crosley Trirdyn 1121 - by radiorich - 04-09-2023, 12:21 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 01:16 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 02:23 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 04-09-2023, 03:51 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 04:18 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 05:39 PM
RE: Crosley Trirdyn 1121 - by GarySP - 04-09-2023, 07:04 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 09:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-21-2023, 06:49 PM
RE: Crosley Trirdyn 1121 - by GarySP - 07-21-2023, 10:49 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 07-22-2023, 07:22 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-22-2023, 12:37 PM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 07-24-2023, 10:46 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-09-2023, 08:44 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 06:15 AM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 08-10-2023, 06:22 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 07:17 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-10-2023, 12:13 PM
RE: Crosley Trirdyn 1121 - by Chas - 08-10-2023, 03:36 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 08-10-2023, 04:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-13-2023, 05:56 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-13-2023, 08:02 PM
