Crosley Trirdyn 1121
Quote:...but I don't have a capacitor tester that measures for leakage at higher voltages.
That is fine on the cap testing with Ohm meter. The Dublier 601's are vacuum impregnated and unless under water or scorched will be fine. Great news on the audio transformers. Modern windings do not use glassine in between the layers the turns are closer together so the added capacitance shunts the higher audio notes.
Recall the MUD parts, re-solder every connection, loosen and re-tighten every electromechanical connection. This is sort of "shotgun" approach, but the mixed metals in both a mechanical and soldered joints do develop a poor connection after some 98 years.
Some of the sheen on the mud parts can be restored by using a modified French Polishing approach using boiled linseed oil rubbed in. Be sure to properly dispose of linseed soaked rags they will spontaneously combust.
Seal the parts (the linseed) to restore the intaglio first, then look to Markal 80220- Paintstik Original B Solid Paint Marker for Oily, Icy, Wet, Dry or Cold Surfaces, Weather- and UV-Resistant, White Color, This product ages in a few weeks to a light wheat color rather than a stark white color. The act of sealing prevents the colorant from creating a whitish haze in the area of application...
Chas
Pliny the younger
Crosley Trirdyn 1121 - by klondike98 - 04-08-2023, 09:29 PM
RE: Crosley Trirdyn 1121 - by Ron Ramirez - 04-09-2023, 08:12 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 08:50 AM
RE: Crosley Trirdyn 1121 - by radiorich - 04-09-2023, 12:21 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 01:16 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 02:23 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 04-09-2023, 03:51 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 04-09-2023, 04:18 PM
RE: Crosley Trirdyn 1121 - by Chas - 04-09-2023, 05:39 PM
RE: Crosley Trirdyn 1121 - by GarySP - 04-09-2023, 07:04 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 04-09-2023, 09:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-21-2023, 06:49 PM
RE: Crosley Trirdyn 1121 - by GarySP - 07-21-2023, 10:49 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 07-22-2023, 07:22 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 07-22-2023, 12:37 PM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 07-24-2023, 10:46 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-09-2023, 08:44 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 06:15 AM
RE: Crosley Trirdyn 1121 - by Eliot Ness - 08-10-2023, 06:22 AM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-10-2023, 07:17 AM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-10-2023, 12:13 PM
RE: Crosley Trirdyn 1121 - by Chas - 08-10-2023, 03:36 PM
RE: Crosley Trirdyn 1121 - by Radioroslyn - 08-10-2023, 04:25 PM
RE: Crosley Trirdyn 1121 - by klondike98 - 08-13-2023, 05:56 PM
RE: Crosley Trirdyn 1121 - by MrFixr55 - 08-13-2023, 08:02 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9468 online users. [Complete List]
» 2 Member(s) | 9466 Guest(s)
