Model 89 code 123
If it is indeed the inner coil of the antenna transformer that is open, what I have done in the past, is use a sewing machine bobbin for a coil form. Your wife may even let you use her sewing machine to wind the coil, if not just use a drill. As you wind, scramble winding as best you can, wind until it looks to be about the same number of turns as the original, the exact number is non real critical.
M R Radios   C M Tubes
Model 89 code 123 - by Griff - 04-10-2023, 11:19 AM
RE: Model 89 code 123 - by MrFixr55 - 04-10-2023, 03:19 PM
RE: Model 89 code 123 - by Steve Davis - 04-10-2023, 08:48 PM
RE: Model 89 code 123 - by Griff - 04-11-2023, 06:29 PM
RE: Model 89 code 123 - by MrFixr55 - 04-11-2023, 10:56 PM
RE: Model 89 code 123 - by Griff - 05-28-2023, 02:32 PM
RE: Model 89 code 123 - by admin - 05-28-2023, 03:55 PM
RE: Model 89 code 123 - by Radioroslyn - 05-28-2023, 06:39 PM
Repaired Model 89 code 123 - by Griff - 05-28-2023, 02:28 PM
