Philco 46-1226: Strange Volume Problem
Yes, even when the volume is at max CCW, the output in AM is still lower than I would expect.
I'll check the switch (again). I've cleaned it a few times, but perhaps there's still oxidation on the contacts.
RE: Philco 46-1226: Strange Volume Problem - by Al Green - 04-11-2023, 10:36 PM
Eico 232 VTVM Schematic
There are currently 9005 online users. [Complete List]
» 1 Member(s) | 9004 Guest(s)
