Philco 46-1226: Strange Volume Problem
Do an experiment. Short out the switch by a piece of wire. Or simply desolder the wires and twist them together to fully exclude the switch and possible wrong connections.
RE: Philco 46-1226: Strange Volume Problem - by morzh - 04-11-2023, 10:49 PM
