Philco 46-1226: Strange Volume Problem
It is a neg. feedback.
Inversion of the output winding or the plate wires of the primary of the output xfmr would also create an interesting behaviour.
Though it probably would manifest itself a bit different....like howling.
Had it once in a Grundig. Boy did it howl.....
RE: Philco 46-1226: Strange Volume Problem - by morzh - 04-13-2023, 10:12 PM
