655 restoration
Hello Pat,
It is fairly easy to stuff the cans just depends if you want to stuff the orinigal capacitors or mount them under the chassis like chas talked about that is the easiest way.
655 restoration - by patmat2350 - 04-19-2023, 01:11 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 11:44 AM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:14 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:30 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:28 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:50 PM
RE: 655 restoration - by admin - 04-27-2023, 07:13 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 07:26 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:13 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:17 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 08:35 PM
RE: 655 restoration - by radiorich - 04-27-2023, 09:11 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:22 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:31 PM
RE: 655 restoration - by patmat2350 - 04-30-2023, 01:02 AM
RE: 655 restoration - by morzh - 04-30-2023, 02:13 PM
RE: 655 restoration - by RodB - 04-30-2023, 06:05 PM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:49 AM
RE: 655 restoration - by Radioroslyn - 05-01-2023, 07:18 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:27 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:40 AM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:53 PM
RE: 655 restoration - by patmat2350 - 05-02-2023, 11:58 PM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:10 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:29 AM
RE: 655 restoration - by patmat2350 - 05-03-2023, 11:15 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 12:52 PM
RE: 655 restoration - by patmat2350 - 05-08-2023, 08:53 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 02:15 PM
RE: 655 restoration - by Jordanbkc - 05-27-2023, 09:46 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 10:15 PM
RE: 655 restoration - by morzh - 05-27-2023, 10:26 PM
RE: 655 restoration - by patmat2350 - 05-28-2023, 01:33 AM
RE: What's My Model? - by patmat2350 - 04-19-2023, 01:30 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:08 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:48 PM
655 restoration - by patmat2350 - 04-19-2023, 07:43 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 07:52 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 07:57 PM
RE: Is my 655 dial OK? - by Steve Davis - 04-19-2023, 08:44 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 10:19 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:44 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:48 PM
RE: 655 restoration - by radiorich - 04-21-2023, 07:40 AM
Is my 655's 8mF electrolytic OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655's 8mF electrolytic OK? - by Chas - 04-19-2023, 10:06 PM
RE: Is my 655's 8mF electrolytic OK? - by morzh - 04-19-2023, 10:22 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 06:39 PM
RE: What's My Model? - by Steve Davis - 04-24-2023, 07:36 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 08:02 PM
RE: What's My Model? - by radiorich - 04-24-2023, 08:13 PM
Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:15 PM
RE: Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:26 PM
