box style shadow meter and magnetism woes
Ok Here's some things to check. Pin 3 of the 42 tube should have about +320vdc from chassis. If it's lower than +300vdc find out why. If your 6A7 or either of the 39/44's have low emission that could cause it. Weak 6A7's are common.  Check #'s 66,26,33,34,and 37 for proper resistance, they may have drifted.
Now I'm assuming that you have replaced all of the foil/paper caps that are inside the bakelite blocks. If you haven't it's a must!
https://philcoradio.com/library/download...%20195.pdf
Happy Troubleshooting!
RE: box style shadow meter and magnetism woes - by Radioroslyn - 04-27-2023, 10:06 AM
Philco 91 Tuning Condenser
There are currently 8533 online users. [Complete List]
» 1 Member(s) | 8532 Guest(s)
