Setchell Carlson Model 427 fluctuating volume
Quote:Peter, Greg said he replaced the 12SQ7 three times by NOS tubes.
Oops. Sorry. Then there are already listed resistors and capacitors. I would observe the change in AVC voltage before and during silence.
Old Tube Radio Online Museum / Музей ретро радіо
https://www.youtube.com/user/RadioSvit?d...lymer=true
Sincerely Peter
З повагою Петро
462ron - by 462ron - 04-29-2023, 07:56 AM
RE: Setchell Carlson Model 427 fluctuating volume - by RadioSvit - 04-29-2023, 04:11 PM
