655 restoration
#47
Thanks. That eBay cable is also foil shielded not braided. But the ground conductor is outside the foils, so it's in contact with the shields, and I can easily terminate THAT.
I'll have to look again at my old cables, maybe I'll get lucky!
BTW, I see that someone, likely my late brother, has been there before and worked on the power switch. I said the shield was only grounded on the other end, but now I see a pigtail on the shield was snipped off at the switch end... So it WAS grounded both ends...
655 restoration - by patmat2350 - 04-19-2023, 01:11 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 11:44 AM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:14 PM
RE: 655 restoration - by patmat2350 - 04-26-2023, 12:30 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:28 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 04:50 PM
RE: 655 restoration - by admin - 04-27-2023, 07:13 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 07:26 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:13 PM
RE: 655 restoration - by Ron Ramirez - 04-27-2023, 08:17 PM
RE: 655 restoration - by patmat2350 - 04-27-2023, 08:35 PM
RE: 655 restoration - by radiorich - 04-27-2023, 09:11 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:22 PM
RE: 655 restoration - by patmat2350 - 04-28-2023, 08:31 PM
RE: 655 restoration - by patmat2350 - 04-30-2023, 01:02 AM
RE: 655 restoration - by morzh - 04-30-2023, 02:13 PM
RE: 655 restoration - by RodB - 04-30-2023, 06:05 PM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:49 AM
RE: 655 restoration - by Radioroslyn - 05-01-2023, 07:18 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:27 AM
RE: 655 restoration - by Ron Ramirez - 05-01-2023, 08:40 AM
RE: 655 restoration - by patmat2350 - 05-01-2023, 12:53 PM
RE: 655 restoration - by patmat2350 - 05-02-2023, 11:58 PM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:10 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 07:29 AM
RE: 655 restoration - by patmat2350 - 05-03-2023, 11:15 AM
RE: 655 restoration - by Ron Ramirez - 05-03-2023, 12:52 PM
RE: 655 restoration - by patmat2350 - 05-08-2023, 08:53 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 02:15 PM
RE: 655 restoration - by Jordanbkc - 05-27-2023, 09:46 PM
RE: 655 restoration - by patmat2350 - 05-27-2023, 10:15 PM
RE: 655 restoration - by morzh - 05-27-2023, 10:26 PM
RE: 655 restoration - by patmat2350 - 05-28-2023, 01:33 AM
RE: What's My Model? - by patmat2350 - 04-19-2023, 01:30 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:08 PM
RE: What's My Model? - by patmat2350 - 04-19-2023, 06:48 PM
655 restoration - by patmat2350 - 04-19-2023, 07:43 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 07:52 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 07:57 PM
RE: Is my 655 dial OK? - by Steve Davis - 04-19-2023, 08:44 PM
RE: Is my 655 dial OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655 dial OK? - by morzh - 04-19-2023, 10:19 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:44 PM
RE: 655 restoration - by klondike98 - 04-20-2023, 02:48 PM
RE: 655 restoration - by radiorich - 04-21-2023, 07:40 AM
Is my 655's 8mF electrolytic OK? - by patmat2350 - 04-19-2023, 09:05 PM
RE: Is my 655's 8mF electrolytic OK? - by Chas - 04-19-2023, 10:06 PM
RE: Is my 655's 8mF electrolytic OK? - by morzh - 04-19-2023, 10:22 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 06:39 PM
RE: What's My Model? - by Steve Davis - 04-24-2023, 07:36 PM
RE: What's My Model? - by patmat2350 - 04-24-2023, 08:02 PM
RE: What's My Model? - by radiorich - 04-24-2023, 08:13 PM
Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:15 PM
RE: Tone Control Rebuild - by patmat2350 - 04-27-2023, 06:26 PM
