46-420 IF Transformer Issue
Thanks, Rod! I've worked on Zenith transformers with mica issues before. I didn't know what the process was trying to get the assembly out of the Philco can. There are two gold tabs on two sides. I didn't know if I needed a special tool or what.
46-420 IF Transformer Issue - by WXmanRich - 05-02-2023, 09:44 PM
RE: 46-420 IF Transformer Issue - by RodB - 05-03-2023, 10:28 AM
RE: 46-420 IF Transformer Issue - by WXmanRich - 05-03-2023, 06:08 PM
RE: 46-420 IF Transformer Issue - by falcon123 - 06-01-2023, 06:25 AM
Eico 232 VTVM Schematic
