Safety Caps for Bakelite Block
I ordered 2 caps @ 58 cents. Postage was around $2. Total order was under $4 - no minimum. Perhaps they have different rules for Canadian orders.
Safety Caps for Bakelite Block - by IraP - 06-10-2011, 07:08 AM
Re: Safety Caps for Bakelite Block - by exray - 06-10-2011, 07:48 AM
Re: Safety Caps for Bakelite Block - by IraP - 06-14-2011, 10:23 AM
Re: Safety Caps for Bakelite Block - by Marsupial - 06-14-2011, 10:26 AM
Re: Safety Caps for Bakelite Block - by codefox1 - 06-14-2011, 10:49 AM
Re: Safety Caps for Bakelite Block - by IraP - 06-14-2011, 10:53 AM
Re: Safety Caps for Bakelite Block - by Marsupial - 06-14-2011, 01:18 PM
Re: Safety Caps for Bakelite Block - by IraP - 06-14-2011, 07:33 PM
Re: Safety Caps for Bakelite Block - by Marsupial - 06-15-2011, 01:32 AM
The speaker table error?
Philco 70 antenna lead
