Removing Tear Drop Type Door Pulls From a Philco 111 Hi-Boy
Arran,
Thanks for your input and comments. I don't see any brad or nail heads around the flanges of the door pulls. There is a possibility the pulls screw into a female captive insert as you mentioned. A friend of mine has suggested having the door x-rayed to ascertain exactly how the pulls are fastened to the door. That may be my next course to unravel this mystery. Your thoughts and comments are appreciated.
Regards,
Floyd
Re: Removing Tear Drop Type Door Pulls From a Philco 111 Hi- - by Radionut78 - 06-14-2011, 09:39 PM
There are currently 3770 online users. [Complete List]
» 2 Member(s) | 3768 Guest(s)
