Model 49-905 FM Antenna
Well, tried it, and it didnt help much. Only a couple of stations with volume all the way up.  Oddly enough when I aligned it, it worked great with minimal volume.  Just wont pick up stations.  AM works great.
Model 49-905 FM Antenna - by reubanks1 - 05-07-2023, 04:40 PM
RE: Model 49-905 FM Antenna - by klondike98 - 05-07-2023, 07:35 PM
RE: Model 49-905 FM Antenna - by reubanks1 - 05-08-2023, 02:07 AM
RE: Model 49-905 FM Antenna - by reubanks1 - 05-08-2023, 01:04 PM
RE: Model 49-905 FM Antenna - by klondike98 - 05-08-2023, 01:46 PM
RE: Model 49-905 FM Antenna - by DaleHCook - 05-08-2023, 02:58 PM
RE: Model 49-905 FM Antenna - by falcon123 - 05-09-2023, 04:15 AM
RE: Model 49-905 FM Antenna - by DaleHCook - 05-09-2023, 08:32 AM
